CFX analysis of a sphere - drag too low
Old   March 22, 2007, 18:47
Default CFX analysis of a sphere - drag too low
Rob Findlay
Just starting out with CFX and I thought to learn I would model a sphere and compare drag with theory.
One inch diameter sphere in 60 m/s airflow should have a Cd around 0.42 with total drag of around 0.46 N. My CFX results give a drag of 0.28 N (62% of theory).
I was hoping people might be able to suggest a number of reasons I could be getting this low result. The output file for the run is located at: http://teambasic.files.wordpress.com...phere2_002.doc
But I will precis what I have done below... I would greatly appreciate any help you can give me.
Regards, Rob
Loosly based on the "flow over a blunt body" tutorial. Default values unless stated.
Steady State, Air Ideal Gas, Shear Stress Transport turb model (y+ at the ball is < 1, approx 15 nodes within the boundary layer thickness). Domain size: 3 x sphere diameter in front and to sides of sphere; 10 x sphere diameter behind. 2 x symmetry planes, 2 x free slip walls. sphere is no slip. inlet is subsonic, normal vel 60m/s, turb 5% medium. outlet is subsonic, static pressure, 0 atm. init conditions: y velocity 60m/s, turb eddy dissip selected. solver control: resudual RMS 1e-5, physical timescale 1/3 of time taken to flow through domain (did another run multiplied by 4, no real difference) mesh adaption based on abs pressure, eddy visc, velocity. 3 steps. total nodes 700,000. Solution Var * edge length. 50 iterations, RMS, 1e-4.
The residuals looked okay, one order magnitude between RMS & max, no major change of drag values as i increased the mesh size. Do I need to be looking at transitional turbulence model??
Like I said, all help would be appreciated! Rob
Old   March 23, 2007, 05:25
Default Re: CFX analysis of a sphere - drag too low
Joe
Domain size: 3 x sphere diameter in front and to sides of sphere ... too small increase to 5.
The nature of the vortex shedding may require transient analysis. Your steady state convergence is poor.
The massive separation may also require DES, SAS-SST i.e. this is an ahmed body like problem.
There may be turbulence transition effects, although your inlet velocities are high.
Calculate the drag coefficient in the solver not in Post.
Old   March 23, 2007, 07:19
Dr Flow Squad
You have used a symmetry plane. So the force is for half a ball or what?
| Pressure Force On Walls
X-Comp. Y-Comp. Z-Comp.
ball 2.4304E-01 6.6143E-02 2.4464E-01
Old   March 25, 2007, 18:45
Rob Findlay
Thanks for your response.
I used two symmetry planes - therefore 1/4 of the ball. I multiplied the force by 4 and that is the value that is 60% of expected.
Cheers, Rob
Old   March 25, 2007, 19:07
Rob Findlay
Joe,
Thanks. I will try all of the above and post another response with my results.
Regards, Rob
Old   March 26, 2007, 03:59
Fonzie
You might also wanna try to use a different advection scheme. In my last project with a blunt body the high-res-scheme did not yield very accurate results. SBF=1 worked much better - however there occured convergence issues from time to time.
Old   March 26, 2007, 10:11
Phil
which means you did not do a mesh refinement study?
Aerodynamic noise analysis with CFX famarcfd Main CFD Forum 0 December 14, 2010 07:53
Aerodynamic noise analysis with CFX famarcfd ANSYS 0 December 13, 2010 06:27
drag in cfx (important) deus CFX 2 July 8, 2008 21:50
calculating drag at low Re no over FX airfoil M. Essuri FLUENT 1 November 1, 2006 15:55
Low Drag airfoils for Supermileage vehicle Himanshu FLUENT 1 December 25, 2005 08:51
