Solid-liquid flow
Old   March 7, 2007, 03:17
Default Solid-liquid flow
Reena
For a solid-liquid flow (sand and water), do I need to set a solid domain and a fluid domain, then connect them with domain interface? If so, which material group should I put the material "sand" so that I can select it in solid list?
Old   March 7, 2007, 05:14
Default Re: Solid-liquid flow
Reena
Sorry, I misunderstand the definition of domain. Now I set the material "sand" and "mixture" (sand, water)in user group. In fluid domain, what is the different to select " mixure" and to select Sand and Water separately at fluid list?
Old   March 7, 2007, 05:39
What are you trying to do? Does the sand get moved around by the fluid or is it stationary like at the beach and the water flows on top of it?
I think you are trying to model sand being moved by the fluid. This is called Lagrangian particle tracking and there is an example in the tutorials.
Old   March 10, 2007, 02:39
Reena
Yes, I am trying to model sand being moved by the fluid. What I have to do is to find the minimum velocity of fluid in order to suspend the sand where the sand is initailly deposited at the bottom of the pipe.
Old   March 11, 2007, 04:32
In that case then look in the documentation for Lagrangian particle tracking. There is also a tutorial example - I think it is the butterfly valve example.
Old   March 12, 2007, 06:32
Reena
Thanks,
I have done the tutorial, but the case is describing fully suspensed sand moving by water. How can I set the sand from stable state (sediments) to suspension state?
Old   March 12, 2007, 16:21
You cannot do that sort of simulation in CFX. You need a discrete particle model to capture the packing of the sand and the release of particles. Have a look at EDEM:
http://www.leapaust.com.au/products/details/edem.htm
Old   March 14, 2007, 03:20
Dr. Flow Squad
Direct link: http://www.dem-solutions.com/
heat conduction in solid and convection in flow kunal FLUENT 3 February 29, 2012 04:42
Modeling two liquid flow mixture hamideh FLUENT 0 June 13, 2011 10:44
Convergence criteria of Solid liquid two phase flow. trystwithgaurav FLUENT 0 August 17, 2009 17:48
solid liquid phase change (melting/solidification) ernane CFX 0 February 3, 2009 14:24
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
