Insufficient Memory Allocated-error
Old   March 26, 2007, 16:16
Default Insufficient Memory Allocated-error
Juan Catelén
I'm having this message while I was trying to make a transient simulation: *** INSUFFICIENT MEMORY ALLOCATED *** | Action required : Increase the integer stack memory size. If the situation persists please contact the CFX Customer Helpline giving the following details: Requested space: 1151286 words | Current allocated space: 1653034 words | | Current used space: 1086470 words | | Current free space: 566564 words | | Number of free areas: 1 What can I do? I have a lot of free memory and I hace tried to make the run in another folder and with a new archive but I always had the same problem.
Old   March 26, 2007, 17:40
Default Re: Insufficient Memory Allocated-error
Joe
Increase the integer stack size in the solver parameters page of the CFX solver manager
Old   April 4, 2007, 03:57
Sameer
Hi Juan. I was also facing the same problem. I tried with increasing integer stack size in solver parameters page but still failed. In my problem there are two domains- one rotating and one stationary. I made changes in settings of domain interface-changed rotational offset value and set pitch change to none. If yours is same kind of problem you can try with this.
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
