May 13, 2007, 13:52 |
INSUFFICIENT MEMORY ALLOCATED
hi all i'm trying to run a steady state simulation in which if used fluid-fluid domain interface between 2 different cubical domain but after exporting the .def to solver; i'm recieving the following error
+--------------------------------------------------------------------+ | | | *** INSUFFICIENT MEMORY ALLOCATED *** | | | | Action required : Increase the integer stack memory size. | | | | If the situation persists please contact the CFX Customer Helpline | | giving the following details:- | | | | Requested space: 2487685 words | | | | Current allocated space: 26446392 words | | Current used space: 25511788 words | | Current free space: 934604 words | | Number of free areas: 1 | | | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = LCON CDTYPE = INTR ISIZE = 2487685 CRESLT = FULL Can anyone plz help |
May 13, 2007, 18:20 |
Re: INSUFFICIENT MEMORY ALLOCATED
In the Define Run menu select the solver tab (advanced controls) and increase the memory allocation factor.
Regs, Gert-Jan |
May 14, 2007, 10:02 |
Because of long time running of CFX it generaly gives such error restart your computer and have a solution.
*** INSUFFICIENT MEMORY ALLOCATED *** ?????? | Pedro lima | CFX | 5 | September 26, 2007 08:28 |
Insufficient Memory Allocated-error | Juan Catelén | CFX | 2 | April 4, 2007 03:57 |
INSUFFICIENT MEMORY ALLOCATED Error for FSI | Cuong | CFX | 2 | November 6, 2006 19:48 |
INSUFFICIENT MEMORY ALLOCATED | Jan | CFX | 2 | July 16, 2003 00:55 |
INSUFFICIENT MEMORY ALLOCATED | xfshi | CFX | 1 | June 19, 2003 18:54 |
