April 17, 2007, 11:01 |
Hub-to-Shroud Diagramm
I want to create a Hub-to-Shroud diagram of the measured pressure along a stage of an axial compressor. By setting "Pressure MCA on Hub to Shroud Line" as my X variable and "Span normalized" as my Y variable I obtain a chart with all my sampling points positioned in a vertical line at a certain constant pressure. If I change the X Variable to "Pressure ACA on Hub to Shroud Line" the sample points then form the correct curve. Did I make a mistake during the settings in CFX-Pre so that CFX-Post can't calculate with mass circumferential averaging? All my other charts are correct. Thank you.
How is Hub to Shroud Line drawn in CFX by default? | arunraj | CFX | 0 | October 14, 2011 07:36 |
Autogrid: discontinuity of 90 degrees in shroud | Eric Joubarne | Fidelity CFD | 1 | July 21, 2009 04:34 |
boundary conditions for hub and shroud | Jasmine | CFX | 3 | March 24, 2009 20:05 |
Stator tip gap at hub in turbogrid /CFX post turbo | Adam | CFX | 1 | May 29, 2006 04:47 |
how to decide the shroud and hub line | angel | Fidelity CFD | 4 | April 1, 2003 02:39 |
