Strange messages at the end of CFX .out file
Old   April 16, 2007, 09:44
Default Strange messages at the end of CFX .out file
Albi
I have found these strange messages at the end of the CFX .out file:
GETCORE stacktrace 1 get_UCOEF_TURB, ,DENSITY_FL1,BELG263/VERTEX,LATEST 2 get_UCOEF_TURB, ,VISCDYN_FL1,BELG263/VERTEX,LATEST 3 get_YPLUS_TURB, ,DENSITY_FL1,BELG263/VERTEX,LATEST 4 get_YPLUS_TURB, ,VISCDYN_FL1,BELG263/VERTEX,LATEST 5 get_YPLUS_TURB, ,YNODE_FL1,BELG263/VERTEX,LATEST
Anyway the solver writes the .res file.
What these messages refers to?
Thanks!!!
Old   April 16, 2007, 12:17
Default Re: Strange messages at the end of CFX .out file
opaque
Dear Albi,
Please contact your ANSYS CFX help representative, and explain your problem. Which version are you using 11.0?. If so, the help desk can test 11.0 Update 1 to check if a similar issue has already been reported/fixed.
If you are interested. The variable gathering system for the CFX solver has failed while computing Wall Transfer Coefficient for the momentum equation at the end of the run, and the stacktrace is a list of incomplete internal calls due to this failure.
Which turbulent model were you running, SST?
Opaque.
Old   April 17, 2007, 02:17
Albi
The turbolent model is the K-epsilon and "heat transfer" is set to none.
I use the version 10.0.
thank you very much for your help, i'll try to reinstall CFX whit the SP1.
Problems of running Oscillating plate tutorial vovogoal CFX 20 February 4, 2016 07:03
Opening velocity varies over time? kingjewel1 CFX 14 January 15, 2010 03:05
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
error using combination of step function xujjun CFX 1 January 15, 2008 16:46
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
