April 16, 2007, 09:44 |
Strange messages at the end of CFX .out file
I have found these strange messages at the end of the CFX .out file:
GETCORE stacktrace 1 get_UCOEF_TURB, ,DENSITY_FL1,BELG263/VERTEX,LATEST 2 get_UCOEF_TURB, ,VISCDYN_FL1,BELG263/VERTEX,LATEST 3 get_YPLUS_TURB, ,DENSITY_FL1,BELG263/VERTEX,LATEST 4 get_YPLUS_TURB, ,VISCDYN_FL1,BELG263/VERTEX,LATEST 5 get_YPLUS_TURB, ,YNODE_FL1,BELG263/VERTEX,LATEST Anyway the solver writes the .res file. What these messages refers to? Thanks!!! |
April 16, 2007, 12:17 |
Re: Strange messages at the end of CFX .out file
Dear Albi,
Please contact your ANSYS CFX help representative, and explain your problem. Which version are you using 11.0?. If so, the help desk can test 11.0 Update 1 to check if a similar issue has already been reported/fixed. If you are interested. The variable gathering system for the CFX solver has failed while computing Wall Transfer Coefficient for the momentum equation at the end of the run, and the stacktrace is a list of incomplete internal calls due to this failure. Which turbulent model were you running, SST? Opaque. |
April 17, 2007, 02:17 |
The turbolent model is the K-epsilon and "heat transfer" is set to none.
I use the version 10.0. thank you very much for your help, i'll try to reinstall CFX whit the SP1. |
Problems of running Oscillating plate tutorial | vovogoal | CFX | 20 | February 4, 2016 07:03 |
Opening velocity varies over time? | kingjewel1 | CFX | 14 | January 15, 2010 03:05 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
