Use of Drysteam as a material in Cfx
Old   April 17, 2007, 06:21
Default Use of Drysteam as a material in Cfx
Ramu Maddi
I am doing hp stage analysis for a steam turbine,when i am using material as 'water ideal gas' I am getting results which are varying around 10% with practical data, but when i am using dry steam in cfx 10.0 as a material I am getting something nonsense, please any body worked in this field help me.
Old   April 17, 2007, 06:45
Default Re: Use of Drysteam as a material in Cfx
Johnny
Are you using the RGP table for dry steam? If so, is there any clipping reported in your out file?
Old   April 18, 2007, 06:04
Ramu Maddi
I am using drysteam and rgp table, I am using cfx 10 when I am referring rgp table I am getting a error in blue color saying that "the material selected does not have thermal conductivity or specific heat".
Old   April 18, 2007, 12:49
HekLer
The error message given by the GUI is a bug. It is fixed in CFX 11.0. Don't worry about it.
Johnny is correct. In CFX 10.0 the presupplied RGP files for steam only allow for certain ranges of temperature and pressure. See the material description in the lower message bar in CFX Pre. When you select a material it must correspond to the pressure and temperature range of your device.
If one of the pre-supplied RGP files does not have a correct range then you will have to use the Redlich Kwong equation of state materials instead. With these materials you can customize the pressure and temperature ranges which the tables are built for inside the solver.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Wall Material Maple FLUENT 4 March 13, 2009 05:39
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
