CFX Post
I would like to port a chart in CFX Post with time as x-axis and pressure as y-axis. However, nothing is showed on the chart. Is there anything I have to set in colver control before running the solver file?
Re: CFX Post
Did you pick the specific point in question, in the chart window? It would not be a problem if u did.
Re: CFX Post
How do you define time in CFX-Post?
Do you have a transient case? Then, as far as I know, you cannot use time on the x-axis because you can only view a single timestep. In that case you should export the value of each timestep to an excel file and create your graph in there. Regs, Gert-Jan www.bunova.nl |
