Home > Forums > CFX
Volume negative
Old   April 23, 2007, 09:05
Default Volume negative
Diego Augusto
I am having problems with elements negative volumes in the simulation of chamber of combustion of an engine diesel, what I must make?
Old   April 23, 2007, 18:13
Default Re: Volume negative
I have already discussed this issue in several posts. Do a search on the forum.
Old   April 25, 2007, 14:12
Gert-Jan
Try to make a mesh without negative elements. What do you use? I suspect ICEM CFD....
Gert-Jan
Old   April 26, 2007, 08:21
Diego Augusto
How I can make a mesh without negative elements? Yes I use ICEM CFD... Thanks a lot
Old   April 26, 2007, 15:58
Gert-Jan
Well, that is just a matter of experience. Do you make a hex mesh or a mix of tets-prisms? You should check the quality of your mesh before you export it to ansys format. Look for the icon with the large Q.
Good luck, Gert-Jan
www.bunova.nl
Old   April 27, 2007, 09:34
Diego Augusto
I always look for to make this, and the quality in the majority of the cases is very good. The mesh that I make is all in the format tetra, will be that I must make in the format tetra-prism? Thanks a lot!
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
