Home > Forums > CFX
ICEM CFD question
Old   April 24, 2007, 08:59
Default ICEM CFD question
arya
I made my model in proe. Now it seems that I need to make a few arrangements to my model. I need to make separation on one surface so that I can separate a surface that once an entity into two or more entities. By doing this I can assign those new area as different part. I need to do this, because I need different mesh quality for each section.
Thanks!
Old   April 24, 2007, 16:39
Default Re: ICEM CFD question
Wooster
Not sure, but I think there is a tutorial in ICEM where it takes a rod and does different meshes along the axial direction. As long as you can do something similar to your geometry that would be the best way.
Otherwise, you'd have to make separate parts in ProE and put them together in assemblies. ICEM picks up the various parts quite well (in my experience) and then you can define the mesh parameters inside.
-M
Old   April 25, 2007, 08:27
Sameer
Arya
In ICEM CFD you can trim a surface in as many parts you want(Geometry--Create/Modify Surface--Segment Surface). Ease of doing this depends on type of surface.In surface mesh setup you can assign required mesh parameters to individual entity.
Old   April 25, 2007, 15:48
Wooster
Thanks Sameer, I didn't know that and I'll put it to use in a couple of models I've been mulling over. Hopfully it'll work for me too and save me some time. -M
Old   April 27, 2007, 04:27
arya
Thank you for all the responses,
I've tried using surface trim, and I choose the option where I split the surface using existing curve, now the problem is how can I make a nice/good straight line in icem? So far it's very convinient if I have 2 lines, then I can make a new midline using those 2 lines.
Old   April 27, 2007, 09:12
myron
If you want to trim the surface along a principal direction - then using the IsoCurves (U-V) curves is easiest - especially if the surface is curved. Geometry > Create/Modify Curves > IsoCurve.
If the surface is flat - create two points at the correct locations - then create a curve (from points) between the 2 points.
Old   May 2, 2007, 04:52
arya
Thanks for all the responses.
Now I am about to make mesh, I choose unstructured mesh (tetrahedral). What would be the guideline for creating such mesh? And what will be the parameters so one can say that the mesh is good or bad.
Thread Tools
Trackbacks are On
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 03:42
How is ICEM CFD mesh file format? Seth CFX 4 March 2, 2008 18:22
ICEM CFD in Workbench marek CFX 1 February 15, 2008 11:35
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 15:37
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
