coal combustion initialization problem
Old   April 27, 2007, 23:48
Default coal combustion initialization problem
Chetan Prahsant
I have completed first phase in which I have solved simulation after giving primary and secondary air boundary conditions with their respective temp. In second phase I have given coal boundary conditions and set 1000k as an ignition temp. After 1000 iterations I checked my simulation result but it is showing no temp rise (no combustion). Please guide me for initialization of combustion in CFX
Chetan Prashant
Old   May 1, 2007, 05:41
Default Re: coal combustion initialization problem
Johnson
I would check the particle trajectories and the also the level of combustible gas in the domain (you can do this by looking at the 'Fuel Gas' mass fraction). If there isn't any, then you need to check your multiphase reactions carefully.
Johnson
Coal Combustion simulation Yogesh FLUENT 2 March 20, 2024 13:19
Model for coal combustion Luk_Fiz CFX 1 April 29, 2014 08:49
Oil combustion problem brajh11 CFX 1 December 7, 2012 01:49
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
Coal combustion tutorial Chetan FLUENT 3 May 4, 2007 00:11
