ICEM 10 mesh question
Old   May 5, 2007, 04:39
Default ICEM 10 mesh question
DAK565656
I build structed mesh in cubic domain using blocking. This domain is divided into few parts. When I change some edge size, all mesh in this domain is changed. This is because the number of nodes on this edge and on opposite edge must be same. So we have picture like this:
|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nb sp|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp& nbsp|&nbsp This is mesh on the first side |&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nb sp|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp& nbsp| ---------------------&nbsp&nbsp This is the edge |&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nb sp|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp& nbsp| |&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nb sp|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp& nbsp|&nbsp This is the mesh on the second size
My aim is to get this kind of mesh structure:
|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nb sp|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp& nbsp|&nbsp This is mesh on the first side |&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nb sp|&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp& nbsp| ---------------------&nbsp&nbsp This is the edge |&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp &nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp| &nbsp&nbsp| |&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp &nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp|&nbsp&nbsp| &nbsp&nbsp| &nbsp This is mesh on the second side
So on the first side I want coarse mesh, on the second side I want two more times accurate mesh (on the second side each node is the beginning of mesh edge, on the first side every second node is the beginning of the mesh edge) How can I achieve this in ICEM 10 using blocking?
Old   May 5, 2007, 13:48
Default Re: ICEM 10 mesh question
Charles
Delete the block on the second side.
Build a new block on the second side, but using points that do not coincide with the existing vertices of the block on the first side.
Then associate the vertices of the interface with points that coincide with the interface vertices of the first side.
Old   May 6, 2007, 09:22
Gert-Jan
You should build two separate meshes for each domain. I am not sure if you can connect them in ICEM. If not, then you can load both in Pre and connect them through a GGI.
Regs, Gert-Jan
www.bunova.nl
Old   May 7, 2007, 03:15
Dr. FLow Squad
Remember that CFX does not support hanging node mesh. You have to mesh them separately in link them together in Pre as Gert-Jan mentions.
Old   May 7, 2007, 09:18
myron
You can do Block Refinements in a given direction. Select the block(s) you want, the direction, and what type of refinement: 1/2 to make coarser - 2 to make finer. When you write the file for Ansys CFX - it will be written correctly such that the interfaces between the elements are there and understood correctly.
Old   May 8, 2007, 11:58
KBanks
Myron, have you done this? My understanding is exactly as Gert and Dr have said, CFX does not support hanging node meshes and the correct approach would be two meshes linked with a GGI in Pre.
Old   May 8, 2007, 12:16
myron
I did this a couple years back - not recently. At that time, ICEM correctly wrote out the interfaces - one for each side of the block refinement. ICEM support would have the final say on this - but I know it worked at one time in V10.0.
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 16:21
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 19:04
