May 8, 2007, 09:26 |
pressure change in CFX 11
I'd like to implement a pressure change between two faces with a domain interface in CFX 11. So I created an domain interface between the two sides and as Interface Models I have the choice between "General Connection" and "Translational Periodicity". In both options I can input a pressure change in Pascal. My problem is that I don't really know what to choose from these two things. Has anybody a good example or tutorial for pressure change in CFX? Thanks for your help |
May 8, 2007, 10:05 |
Re: pressure change in CFX 11
Use General Connection.
May 8, 2007, 10:34 |
Thanks for your quick answer.
I have selected the General Connection option and the solver crashes immediately after the start with the error message "No control surfaces have been found at all for airinterface. To work around this please set the expert parameter "ggi permit no intersection = t"". When I set this parameter to true, the run does not converge. Greg |
May 8, 2007, 15:05 |
Did you pick faces for the interface? I assumed by your earlier description that it was an internal face, in which case you would use General Connection. If it is a periodic connection (i.e. what goes out one end comes back in the other) then you should use the periodic connection instead.
This is all explained fairly clearly in the documentation. -Robin |
Display Modes | |
the pressure coefficient vs angle in CFX?? | Jwolf | CFX | 1 | December 14, 2012 07:31 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
pressure change and angular velocity | Mangnan | CFX | 2 | June 25, 2004 19:26 |
CFX pressure based | clifford bradford | CFX | 12 | June 19, 2001 23:03 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 05:05 |
