May 8, 2007, 11:41 |
Error while partitioning
Anyone got any ideas what this means? I'm trying to partition something when it happens. Details of error:- ---------------- Error detected by routine PEEKCS CDANAM = /FLOW/PHYSICS/ZIF0 /PHYTYPE CRESLT = NONE
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The CFX-5 partitioner exited with return code 1. | +--------------------------------------------------------------------+ The MEMERR part made me think it might be memory related i.e. running out, but I tried an allocation factor of 3, which made no difference and monitoring the memory usage suggests I'm nowhere near running out. The grid is about 9 million nodes. The peak memory usage is 199MB - it has access to 16GB! |
May 8, 2007, 16:16 |
Re: Error while partitioning
Dear KBanks,
Unfortunately, the message is confusing because the ANSYS CFX memory system failed while looking for the physical type of a domain interface (ZIF0). It seems the physics setup is not complete, or a bug in the code. Check your setup carefully.. Otherwise, you must contact your ANSYS CFX help representative. Opaque. |
Partitioning problems in the parallel job | Neo | FLUENT | 5 | January 26, 2021 10:10 |
Weight in graph of mesh partitioning algo. | Joseph | Main CFD Forum | 9 | January 31, 2017 04:53 |
Partitioning | Tristan | CFX | 3 | December 2, 2008 12:36 |
Cicumferential Partitioning in CFX-11.0 | Khaled M. Essa | CFX | 2 | August 16, 2008 13:05 |
Using load vector for parallel partitioning | Kevala | FLUENT | 0 | May 1, 2001 12:11 |
