May 9, 2007, 11:02 |
Define initial liquid level for VOF model
Hi All,
Can someone please suggest how to define an initial liquid level for a vof model? In Fluent, there is a function 'patch' to do this. I am not sure if CFX also has a similar tool. Thanks, Gab |
May 9, 2007, 14:30 |
Re: Define initial liquid level for VOF model
You can use a step function with a coordinate. For everything above x=0 to be gas use:
VfGasIni=0.999*step[x/1[m]] VfLiquidIni=1-VfGas Remember to provide a decent pressure distribution as well. This is very well documented in the help. Please read it good. Another good advice is to use a minimum fraction of 1e-5. Do not use 0 as this will lead to problems..... Gert-Jan www.bunova.nl |
May 9, 2007, 23:42 |
Thanks a lot!
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
