May 11, 2007, 05:30 |
Scalar Equation source term
Hello there!
Actually, I would like to solve some scalar equation in the calculationg domain. each scalar equations have its own source which can be calculated by an expression. I have made some specific additional variables (scalar type). In order to add source, I used a subdomain. In subdomain setting>Fluid>Equation Source I used Total Source option to add the source term of each additional variable equation. But the solution is not correct.Do you think the procedure which I have used is right? If not, could you please give some hints? Thanks, Merck |
Source Term on Scalar Transport Equation - crashing simulation | alessio.nz | OpenFOAM | 19 | February 8, 2011 07:38 |
Adding implicit source term to momentum equation | fs82 | OpenFOAM | 6 | September 23, 2009 03:29 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
How to add a source term in u or v equation? | luckyluke | Phoenics | 3 | December 13, 2004 02:52 |
The source of user scalar equation | rambol | CFX | 3 | November 14, 2002 07:37 |
