Importing mesh problem
Old   May 14, 2007, 14:29
Default Importing mesh problem
ParodDav
Hi everybody, I'm trying to import a model with a mesh made with ICEM 10. This is a Tetra/Prism mesh and the model is quite complicated (solid domains with different materials and fluid domain). This model should solve the solid thermal problem and the fluid dynamic one (around the solid parts). I have a problem importing the mesh into CFX because, when defining boundary conditions and interfaces, my regions are completely divided. For example: I have to define a solid surface which interfaces with the fluid material (or with another solid surface, to define the solid-solid interface). When looking on the regions list (region panel with the available regions for my domain), this surface is composed by several mesh parts (the sum of many of them composes the whole surface I'm working on). Is it a CFX problem? Am I writing the mesh wrongly? Has anybody experienced the same problem? How can I solve it?
Thank you very much in advance! Best regards Davide
Old   May 14, 2007, 18:15
Default Re: Importing mesh problem
Either in CFX-Pre multi-select the parts which make up the total boundary condition or interface; or you can fix it in ICEM manually. Occasionally ICEM needs a little help correctly allocating part names to boundary faces. Turn the geometry off, right click on a part and choose edit part. You can then add elements to a part and manually fix things up.
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
problem related to mesh naveen CFX 3 March 25, 2006 08:47
