-   -   Model for Capillary (http://www.cfd-online.com/Forums/cfx/23978-model-capillary.html)
mathew May 14, 2007 10:33
Model for Capillary
hi,
i am trying to modell a simpel capillary effect. i got a 2D modell from a capillary and want to simulate the water runnig out of region between two pins (like a 3d hole in a surface).i will make it a twophaseflow with freesurface, so the air can fill up the capillary. The mesh is fine enough to represent the expected curvature. Do i have to start with initializing water and the air with 50% volume fraction each in the whole domain and do a steady state run OR initializing with air in the whole flow domain and create water inlet at the sides/top and do transient run?? does cfx model capillary effectes by setting up surface tension and wall adhesion?
thanks a lot
mathew
Gert-Jan May 14, 2007 16:11
Re: Model for Capillary
Yes, CFX can handle this. However, you have to include a surface tension and a surface tension model.
Remember that you have to use very small timesteps because surface tension is implemented explicitly.
Gert-Jan
www.bunova.nl
mathew May 15, 2007 04:30
thank you for your response
ive chosen 5x10^-6 for the timestep so the simulation is taking a long time but i finally reached 6 coeff.lops so that is quite okay with me. I have a free surface flow with two continuous fluids,therefore i only have a "Continuum Surface Force" and a primary fluid which is water in my case. Actually i am doing a singel-bubble-evaporating at a wall and now i am trying to include more and more physical forces.
mathew
