How to open the ICEM help with java?
The help can not be opened from my ICEM GUI, for ICEM5 i can open it, but when I try to open help in ICEM 11, the GUI will always freeze. So I try to seek a way to open the help using java command directly. I try to use
java -jar icemcfd_help.jar but I get the error message like this Failed to load Main-Class manifest attribute from icemcfd_help.jar I'm using icem on Suse. Could some on tell me how to open these jar help file from command line? Thanks |
Re: How to open the ICEM help with java?
add the environment variable maybe CFX5JAVA=%JAVA_HOME%\bin\java.exe
you shoud check out the variable. |
i'm using linux. i tried to set CFX5JAVA enviroment, and it can find the java, but the GUI still freeze when I click the help. Thanks anyway.
