Inviscid Euler flow
Old   May 18, 2007, 04:18
Default Inviscid Euler flow
Ryan Sidin
I would like to know if its possible to solve the inviscid Euler equations in CFX11. I saw a few previous threads where the same question was asked, but there the recommendation was to use laminar flow with suitably small viscosity. An inviscid solution is however never the same as a viscous solution even with the lowest of viscosities, unless of course you argue that numerically you always have to deal with artificial viscosity.
Can anyone please tell me if it is possible to solve the inviscid Euler equations in CFX11 without resorting to the previously mentioned method?
Old   May 18, 2007, 22:36
Default Re: Inviscid Euler flow
Omer
I tried it with CFX and also with FLUENT with the inviscid option. But it doesn't work as you would ideally want it to, the results are still of viscous flows. These solvers aren't designed for that , I guess. Or can someone correct me?
Solving Inviscid Compressible Flow mecbe2002 OpenFOAM 3 March 5, 2010 12:47
SIMPLE method for inviscid flow abcdef123 Main CFD Forum 0 February 26, 2010 08:24
Inviscid flow solver luca_g OpenFOAM Running, Solving & CFD 0 December 21, 2006 12:55
Inviscid solver : separation of the flow Jean-Marie Cavet FLUENT 1 September 2, 2003 12:32
Axisymmetric Inviscid Compressible Euler code. Amith Main CFD Forum 2 June 10, 2002 23:32
