recirc tank, inlet outlet conditions
Old   May 21, 2007, 08:54
Default recirc tank, inlet outlet conditions
david
If I have a simple tank which I take water out via a pump and then pump it back into the tank again, a simple recric system, is there a way I can tie the outlet BC to the Inlet BC.
Eg If I take out 6000l/hr through the outlet, how can I specify the inlet to be a function of the outlet velocity / mass flow rate etc?
Thanks
Old   May 22, 2007, 03:23
Default Re: recirc tank, inlet outlet conditions
Gert-Jan
On the run you can calculate the massflow through the outlet: massFlow@Outlet.
This can be used to specify the massflow through the inlet.
Regs, Gert-Jan
www.bunova.nl
How to set pulsating inlet boundary conditions with a very high frequency Ton CFX 10 March 22, 2012 16:57
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 12:41
Outlet conditions in BuoyantFoam jont OpenFOAM Running, Solving & CFD 2 October 15, 2007 07:55
Periodic BC on Inlet and Outlet of a Duct Steve CFX 2 August 8, 2005 12:03
Inlet and Outlet Boundary conditions for LES Jan Ramboer Main CFD Forum 12 August 6, 1999 22:00
