conjugate heat transfer
i use ansys 9.0 to simulate conjugate heat transfer problem include fluid and non-fluid domain. but the non-fluid domain has no temperature field. element:141 fluid material number:1 non-fluid material number:>1 flow and temperature equations are solved at the same time. transient analysis is true Do i need set something else?
Re: conjugate heat transfer
There is a tutorial that covers CHT.
Thank you for your reply! i do it as ansys help told me, but the result seems wrong. the solid domain has no temperature field, which is still the surrounding temperature, no change. do you have any more tutorials or do like this? Give me some suggestions. thank you.
