Convergence then Divergence
Old   May 29, 2007, 02:55
Default Convergence then Divergence
Zurayk
Hello all, I have a question about a simulation I have, that starts converging for a good limit and if left to iterate ore it starts to diverge. in this case is it ok if I consider the results before divergence (after reaching a good limit of convergence)? or does this mean that the whole simulation is diverging and useless?
Old   May 29, 2007, 07:58
Default Re: Convergence then Divergence
Gert-Jan
No. Convergence is just one of the useful parameters to judge you solution. Look at imbalances too and use monitor points. When the imbalances are 0 and the monitor values are constant, and residuals are below 1e-5, then you might have a converged solution. But then you still need to perfroms checks.
Gert-Jan
www.bunova.nl
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Convergence then Divergence Ryan FLUENT 1 August 6, 2004 00:46
