May 28, 2007, 07:11 |
expirience with deforming mesh/mesh motion
Hey everybody
I am currently trying to simulate a free motion of a bridge deck, and are using Fortran to define the vertical and rotationdisceplacement of the bridge deck/of the coordinates (nessesary in Ansys 10. To update the motion based on the forces calculated in Ansys a fourth order Runga-Kutta method is used. PROBLEM: Using the above mentioned method the solver terminates with error because of to large calculated forces by the solver resulting in to large discplacements of the bridge deck, and therefore mesh curling and negative volumes. Does anyone have any experiences with simulating such a combination of rotation and vertical motion using the deformin mesh method? Or an alternativ approach? Can be noted that no problems have occured simulating rotation or vertical motions separatly. Regards JS |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Wankel rotor Deforming mesh and motion UDF_Help please | Catthan | FLUENT | 1 | August 3, 2011 08:04 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
Automatic Mesh Motion solver | michele | OpenFOAM Running, Solving & CFD | 10 | September 26, 2005 08:21 |
IC piston motion - deforming meshes | AMV | FLUENT | 0 | September 16, 2003 13:10 |
