Home > Forums > CFX
Thermocapillary/Marangoni Convection in CFX
Old   May 30, 2007, 06:16
Default Thermocapillary/Marangoni Convection in CFX
Seamus
Hi, I'm trying to simulate the Marangoni convection caused by the presence of a bubble situated on a heated surface, but I'm having many problems. Firstly, how should I try to model this? Should I use two domains, one for air and one for my liquid, or should I represent the bubble by a volume fraction? I need to specify a fluid pair to have the surface tension option become available, but how can you specify a varying surface tension (one that varies with temperature)? I have tied a simple linear variance, but get an error stating I need some prefix for phase or particle.
Any help will be greatly appreciated,
Seamus
Old   May 30, 2007, 06:33
Default Re: Thermocapillary/Marangoni Convection in CFX
Phil
Have you successfully validated a bubble free maragoni convection simulation?
Old   May 30, 2007, 07:10
Seamus
Do you mean a free-surface model? I have not been able to specify a varying surface tension coefficient, so I can't include Marangoni forces,
Old   May 30, 2007, 08:03
Gert-Jan
I should use one domain and a volume fraction for the bubble. However, I doubt if CFX can do the job. You need to know that surface tension is implemented explicitly and that you need a very fine mesh. Therefore you will need a lot of iterations and a very small timestep.
Perhaps you could consider Fluent or Star CD with a VOF method. Or an academic tool specifically created for this type of problem?
Good luck, Gert-Jan
www.bunova.nl
Old   May 30, 2007, 10:15
Joe
I dont think CFX even has a facility for varying the ST coef.
Old   May 30, 2007, 10:19
Seamus
In the modelling notes it says the Marangoni force will be automatically included if the surface tension is variable. I have asked for technical support from CFX but am yet to get any feedback.
Old   May 30, 2007, 20:38
Phil
Thread Tools
Trackbacks are On
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
natural convection in ANSYS CFX 10 cryo man ANSYS 0 June 9, 2009 07:53
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
