May 14, 2007, 09:34 |
CFX application to radial inflow gas turbine
As a new user for CFX i solved all the tuorials available. My application is radial inflow gas turbine. 1. Will you please guide me what CFD analysis work can me done on his topic using CFX. 2. Any published work or benchmark problem is available for the same?
May 14, 2007, 18:27 |
Re: CFX application to radial inflow gas turbine
There should be plenty of benchmark, validation and verification studies in the general literature. Try google scholar. Glenn Horrocks |
May 16, 2007, 10:15 |
CFX application to radial turbomachines
I am unable to do Fluid Structure Interface tutorial for aerodynamic and structure analysis of centrifugal compressor in CFX10.00 which is available in CFX 11.00.
May 30, 2007, 01:58 |
Re: CFX application to radial turbomachines
Hi chetan, you can definately do FSI in CFX 11. I have also worked on radial inflow gas turbine (flow analysis ).
June 2, 2007, 13:12 |
Re: CFX application to radial inflow gas turbine *NM*
June 2, 2007, 13:13 |
Re: CFX application to radial turbomachines *NM*
Convergence of Radial Turbine Simulation | Hugh | CFX | 10 | June 30, 2010 08:08 |
radial turbine flow analysis | ME | Siemens | 1 | August 16, 2007 03:06 |
radial turbine flow analysis | ME | FLUENT | 0 | July 2, 2007 09:18 |
gas turbine simulation setup | Petr | CFX | 23 | February 21, 2005 03:05 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
