Home > Forums > CFX
Reg. convection
Old   June 9, 2007, 09:03
Default Reg. convection
Michelle
hi, I have been trying to simulate the following problem(Tian and Karayiannis).
A square cavity(0.75x0.75x1.5m) has two isothermal vertical walls maintained at 50 c and 10 c,top and bottom (1.5x0.75) are made of steel(1.5mm) covered by polystyrene layer(100mm) and wood layer(100mm),the front and rear faces(0.75x0.75) are adiabatic.
The litreature says that it can be treated as two dimensional problem.
I succeeded in creating a 3d mesh that was one cell thick in the z-dir.(i.e) I created a square (0.75x0.75)in the xy plane and extruded it to one cell thickness in the z direction.
But im confused about the boundary condition! While i can specify the conditions for the isothermal walls,i am uncertain what boundary conditions to use for the conducting walls.Do i specify the front and rear(0.75x0.75)faces as symmetry planes?
i remenber having read in previous posts that someone had already worked on the same problem!I d be glad to get some ideas and a good explanation of symmetry plane boundary condition!
P.S :I have read the 'help' but im not able to relate the info given there to this problem.!
thanks and regards,
Old   June 9, 2007, 17:36
Default Re: Reg. convection
Johnson
Dear Michelle,
The front and rear faces should be specified as symmetry planes if the problem is 2 dimensional.
For the top and bottom walls, you can calculate the overall thermal resistance of the steel/wood/polystyrene layer from their thermal conductivities and thickness. You can then apply a 'heat transfer coefficient and outside temperature' thermal boundary condition directly to the boundaries, without physically modelling these layers.
Regards,
Johnson
Old   June 11, 2007, 15:13
Michelle
Hi Johnson...
Thanks a Lot..
Thats sorta clarified my point!!
regrds, Michelle
Thread Tools
Trackbacks are On
Convection with Shell Conduction Corentin FLUENT 7 January 30, 2012 14:12
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Coupled vs Seg - Natural vs. Forced Convection Alex CD-adapco 5 December 12, 2007 05:58
heat convection in a forced fluid Daniele Main CFD Forum 0 December 20, 2005 09:09
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 02:54
