CEL expression
Old   June 12, 2007, 05:12
Default CEL expression
Selim
Hallo,
I have the option Velocity u.Gradient x in CFX 5 ,fine.
But I need also gradient of this expression?
How can I do that?
thnks Selim
Old   June 12, 2007, 09:08
Default Re: CEL expression
opaque
Dear Selim,
Would you mind sharing your need for a second derivative of velocity? Perhaps there are other alternatives..
The gradient of the gradient of a vector is a third order tensor, that is not available via CEL.
Opaque
Old   June 13, 2007, 10:26
Selim
Hi opaque,
Actually I need the gradient of a scalar. Temprature,x-component of velocity etc. Is there a way to get from CFX post?
Thnks, SElim
Old   June 13, 2007, 11:14
opaque
Dear Selim,
Check in the Variables tab for CFX-Post. If the <variable of interest>.Gradient <X/Y/Z Component> is not already listed, it is not available at all.
Gradients are usually written for variables that are used for the High Resolution/Specified Blend Factor advection schemes..Otherwise, they are not written to the results file, and consequently unavailable in CFX-Post..
You could create an Vector Algebraic Additional Variable in CFX-Pre, and set the values to the gradient components you need.. Then, this AV will be written to the results file.
ADDITIONAL VARIABLE: MyAvForTempGrad
Option = Vector Algebraic Equation
Vector xValue = Temperature.Gradient X
Vector yValue = Temperature.Gradient Y
Vector zValue = Temperature.Gradient Z
END
The above should work in ANSYS CFX 11.0, in 10.0 you must use UserFortran to access the gradients..
Hope it helps,
Opaque
Old   June 14, 2007, 07:27
Selim
Thanks in advance,
Isnt there anyway to do it with Post? Not so easy for me to do the calculations from the begining
Regards, Selim
Old   June 14, 2007, 09:03
opaque
Dear Selim,
If your case is steady state, you only need to restart the solver for 1 iteration.. For the transient case, do you need the gradient at all timesteps, or only at the last one? For the latter, just run an additional time step.
Hope it helps,
Opaque
Old   June 14, 2007, 10:51
Sohag
Sorry to distrub both of you. I also want to wite a velocity gradient e.g at the wall velocity u=(delu/deln), n is the normal inword to the wall. How I can write it using CEL expressions in CFX-10.I would be very grateful to you if you give me any informations.Please help me. Sohag
CEL expression vmlxb6 CFX 1 March 18, 2011 06:39
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Help needed for writing CEL expression kmgraju CFX 5 September 20, 2010 18:30
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 17:23
