BSL k-omega model in CFX 10
Old   June 12, 2007, 10:25
Default BSL k-omega model in CFX 10
Kasper
Hi!
Is the BSL k-omega model available in CFX 10? It is not listed when choosing turbulence models in CFX-Pre but I thought perhaps it is available through CCL. I have checked the manual but so far no luck.
/Kasper
Old   June 12, 2007, 11:24
Default Re: BSL k-omega model in CFX 10
Robin
It's there. Click on the [...] button next to the pull down list.
Old   June 12, 2007, 11:40
Kasper
I am afraid it isn't. The regular k-omega model is there but not the BSL version. Likewise the manual doesn't list it. On page 145 of the CFX-Pre manual the available turbulence models are listed. I've pasted it in below.
You can select one of the following turbulence models (the advanced model controls, which are discussed in each section): • Fluid Dependent: ... • k-Epsilon: ... • None (Laminar): ... • Shear Stress Transport: ... • QI / SSG / LRR Reynolds Stress: ... • Zero Equation: ... • RNG k-Epsilon: ... • k-Omega: ... • Omega Reynolds Stress / BSL Reynolds Stress: ... • LES Smagorinsky: ... • Detached Eddy Simulation: ...
/Kasper
Old   June 12, 2007, 13:35
Robin
It should be there... I'm looking at it right now. Note that it isn't called "BSL k-omega", just "BSL". It isn't controlled by a specific license either. The formulation is discussed in the manual, but nothing more. BSL was never a very good model and SST was developed to resolve its defficiencies so its use is not encouraged.
Other than academic interest, is there a specific reason you want to run this?
If you still can't see it, here is the CCL:
FLOW:
DOMAIN: Domain 1
DOMAIN MODELS:
TURBULENCE MODEL:
Option = BSL
END
TURBULENT WALL FUNCTIONS:
Option = Automatic
END
END
END
END
-Robin
Old   June 12, 2007, 13:39
opaque
Dear Kasper,
Robin is correct.. It is there after clicking on ...
It is listed as BSL
Are you looking at multiphase flows?
Regards, Opaque
Old   June 13, 2007, 03:42
Li Rong
Actually I have the same problem with Kasper. I click the ... button, but there isn't BSL model but BSL Reynolds stress model, I don't think they are the same model
Old   June 13, 2007, 04:37
Li Rong
By the way, I also don't know how to activate low Reynolds k-e model in CFX, would you give me a hint? Thanks a lot!
Old   June 13, 2007, 05:34
Li Rong
I tried the .ccl file that Robin provided, but CFX gave the following error information:
CCLAPI::validateData - CCL validation failed with message: Error: Sub-object 'TURBULENCE MODEL' is not allowed in /FLOW/DOMAINomain 1/DOMAIN MODELS Error: Sub-object 'TURBULENT WALL FUNCTIONS' is not allowed in /FLOW/DOMAINomain 1/DOMAIN MODELS
BSL k-w model is forbidden? Why?
Thank you!
Old   June 13, 2007, 06:47
Kasper
Hi again!
Apparently this is not such an easy question since some people can use the model and some can't.
http://imageshack.dk//viewimage.php?...e/9Ib29514.jpg
The above link is to a screengrab showing that the BSL isn't in my list. I tried using the CCL but got the following response from Pre:
The parameter "Option in "/FLOW/DOMAIN:Bump/FLUID MODELS/TURBULENCE MODEL" has the value "BSL". This does not match any of the allowed values: "Laminar, k epsilon, SST, Zero Equation, ...".
I am interested in the BSL k-omega model mostly for comparison purposes. I have a case where the SST model underpredicts the turbulent stresses thereby leading to an overprediction of separation. So I was interested in seeing the effect of the delimiter of the eddy-viscostiy in the SST model by comparing to the BSL model.
/Kasper
Old   June 13, 2007, 07:22
opaque
Dear Kasper,
Thanks for the snapshot.. It seems you are running ANSYS CFX 10.0.. Unfortunately, BSL was not available in the GUI back then.. It is in 11.0, and why Robin and I can see it listed..
If you managed to set the Option = BSL, and got the warning
Just write the definition file, and try it in the solver.. It should run.. I do not recall exactly why it was not in the GUI for 10.0
Good luck,
Opaque.
Old   June 13, 2007, 10:29
  #11
Juan Martin Catelén
k-w is a low reynolds model and SST is a combination that uses k-w next to the walls and elsewhere k-e. Bye.
Old   June 13, 2007, 18:34
  #12
Kasper
Hey Opaque!
It worked when using the CCL and ignoring the warnings from Pre when writing the .def file. The Solver started and finished without any problems.
Thanks for the help!
/Kasper
Need Help to Enable Wall Boiling Model in CFX cjhaw CFX 3 September 26, 2013 09:40
Basic advice on Importing Solid Edge model to CFX needed. stephen__white CFX 1 February 9, 2011 18:40
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Import Fan 3D Model - Workbench or CFX? Stewart Long CFX 2 October 28, 2008 04:05
Use of 1 equation turbulence model in CFX 4.3 Niels Deen CFX 0 July 19, 2000 08:50
