June 12, 2007, 10:27 |
Pressure fluctuations, free surface
Hi!
I am performing a 2d - filling simulation where a high viscous fluid is replacing air in a cavity. During the simulation there is a heavy fluctuation in the pressure over the interface, which eventually crashes the simulation. The fluctuation has a checkerboard shape with large positive and negative values and changes in time. Anyone have an idea on how to fix such a problem? The domain has three boundaries with prescribed velocity (opening) and an outlet with prescribed pressure (outlet). Thanks! - Terje |
June 12, 2007, 10:41 |
Re: Pressure fluctuations, free surface
In CFX10 or 11?
June 12, 2007, 11:32 |
What's your time step and Courant number? I've done some filling, including 2D, simulations (Reaction Injection Moulding filling simulations). Can you specify more details, like: what does your 2D geometry look like, what mesh you use. Does the simulation crash after a few timesteps, or after many? What's your Re number? Can you post a link to some pictures showing the volume fractions distribution, and those presure flutuations? And by the way: what's the third boundary? A wall? And why do you set the inlet boundary as an "Opening" and not an "Inlet"? Rui |
June 12, 2007, 12:31 |
Hi!
Thanks for your answers. I will try to provide some more details. I do not have acces to the simulation from here so pictures will have to wait. I am using CFX 11 and am modellng injection molding of a plate which is 1 mm thick. On top of this plate there are located microstructures with dimension approximately 1 um and what is really interesting is the filling of these. However, I do not regard it possible to perform one simulation that includes both the main structure and the microstructures because of the size differences. Therefore, I have used an analytical solution to the free surface flow between parallel plates as a boundary condition to a small scale (10 um x 10 um) simulation around the microstructure. The boundary can be divided in three: - One wall, no slip - One interaction with the main flow field. Here fluid is both entering and leaving at different places at different times and I thus found that neither inlet nor outlet could describe it. So I used opening and prescribe the velocity field and volume fraction from the analytical solution. - A venting channel on the top of the microstructure where I just use a pressure outlet. The simulation runs for quite some time before crashing, but I think this is due to a very low Courant number Co_max = 1.5. which stops the fluctuations from growing too large. Re < 1. I am using a hexagonal mapped mesh. - Terje |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
Variable Density - Free Surface with FIDAP | Vitaliy Pavlyk | FLUENT | 7 | May 2, 2000 15:56 |
