Home > Forums > CFX
Oil mists
Old   June 13, 2007, 10:23
Default Oil mists
Juan Martin Catelén
Hello. Has anybody performed an analysis of oil mist transport in air? If so, wich model did you use? Multicomponent? Additional variable with a transport equation? Particle tracking? I'll be waiting for your answers. Thanks in advance.
Old   June 13, 2007, 10:59
Default Re: Oil mists
Gert-Jan
How must oil do you expect?
How is the oil defined? Narrow diameter distribution?
What are the question that you have to answer?
Gert-Jan
www.bunova.nl
Old   June 13, 2007, 11:31
Juan Martin Catelén
It is for cutting operations. The particle size will depend on where they come from (cutting or transportin of the oil). I'm comparing different possibilities for the extraction system. Bye.
Old   June 13, 2007, 15:34
Gert-Jan
When talking about a mist of oil in air, I would start with a homogeneous model, using the oil droplet as a dispersed phase.
When talking about a cutting process I am not so sure anymore. Sounds like you have pure liquid oil as well in your process. You should treat this as a continuous phase. Thus, you have two continuous phases. Then I would use a mixture model. Be careful, this analysis is not trivial.
Gert-Jan
www.bunova.nl
Old   June 13, 2007, 15:35
Juan Martin Catelén
Ok, thanks. I'll be trying.
Thread Tools
Trackbacks are On
oil aeration problem wprostaff FLUENT 0 July 19, 2011 15:41
Solid partilcles + oil flow suresh OpenFOAM Running, Solving & CFD 2 February 1, 2011 06:08
CFX Model for dispersion of gas through a porous media filled with Oil deepmetal CFX 13 November 27, 2010 21:34
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
oil vapour properties mAx FLUENT 1 July 30, 2002 11:01
