-   -   Multi domain performance penalty???? (http://www.cfd-online.com/Forums/cfx/24114-multi-domain-performance-penalty.html)
Stu June 13, 2007 20:59
Can someone tell me if there is a performance penalty when using multiple domains in a sim. Example, I have a large tank, that I have meshed using icem and cfx-mesh. CFX-mesh for the more complex inlet pipes and Icem for the bulk of the rest of the tank. I join the domains together in cfx-pre and all works well.
Neglecting any difference in nodes/elements/tets/hexes, would the solution take longer to solve because it is using 2 doamins, or would it be faster if I did the entire mesh using 1 domain.
Thanks Stu
Joe June 14, 2007 05:43
Re: Multi domain performance penalty????
In the problems I've solved I've noticed little to no penalty. These were simple linear geometries with a domain interface in the middle.
Gert-Jan June 14, 2007 18:41
The GGI's will deliver a small penalty.
For parallel processing the penalty can be larger. CFX has the drawback that each partition needs at least a part of each domain. So when you have 10 small parts and 1 large part and 3 processors, these 10 small parts are partitioned over the 3 processors as well as the large parts. Even if the 10 small parts would fit on 1 processor.
Gert-Jan
Glenn Horrocks June 14, 2007 18:46
Whether multiple domains decreases efficiency is problem dependant. The issues are:
Increased efficiency due to: 1) Possibility of improved mesh quality and sizing compared to single domain
Decreased efficiency due to: 1) In parallel, partitioning is done on a domain by domain basis (by default) so there the partition interface area increases. 2) There is an overhead in interfaces. 1 to 1 interfaces have almost no overhead but GGI interfaces have a small overhead.
The balance of these issues determines the effect of the interfaces.
johnny June 14, 2007 22:36
By default, CFX runs in "Independent Partitioning" which behaves as Gert-Jan describes. However, you can run "Coupled Partitioning" and then the partitions do not have this restriction.
Gert-Jan June 16, 2007 13:30
Hmmmm, learning every day. Since when does this option exists?
Gert-Jan
johnny June 18, 2007 05:46
I think it has been an option for a long time. Definitely it was there in 10.0.
Gert-Jan June 18, 2007 07:32
I started with CFX 5.3. It was not present there. Hard to keep up all the new features.......
Gert-Jan
Glenn Horrocks June 18, 2007 18:57
Yes, it has been there for a while. I have played with it a long time ago for my simulations with a few GGIs in the hope it increased the simulation speed but it actually made it marginally worse. Not sure why.
I would be interested to hear if it works better now, or if it is an improvement for some simulations and not for others.
