2 velocity vectors
Old   June 19, 2007, 13:16
Default 2 velocity vectors
ashish
Dear all, I am solving a free surface flow problem using inhomogeneous model. When i plot the velocity vectors i can see single velocity vectors on vertex points. When i export the velocity vectors as .dat files and plot it in MATLAB using quiver command it gives error called duplicate data points in MATLAB, however it still plots the vectors. However when i look closely i can see there are two velocity vectors coming out from a single point. This gives error while calculating the stream function in the flow. Any idea why we see the two velocity vectors in MATLAB plotting, but not in CFX-POST ? Thanks, Ashish
Old   June 19, 2007, 14:27
Default Re: 2 velocity vectors
Johnson
inhomogeneous free surface has a velocity field for each phase at each location. You should check the variables in your export file - I suspect you have both fields there - and export only the ones you want.
Johnson
Old   June 19, 2007, 18:13
As Johnson said, there is an independent velocity field for both phases when you select inhomogeneous. That is why you can see two vectors at each point.
Most free surface flows can be modelled with homogeneous velocity fields. Then the velocity field is shared for all phases. Should run much faster too, with heaps less memory.
Have a read of the documentation about multiphase flows including the best practises guide.
Old   June 19, 2007, 18:32
Ashish
Hi Johnson and Glenn, Its true that we have 2 variables at each point for both the phases. But if i export just *.superficial velocity X, *.superficial velocity Y on a plane, i think it should only have velocity field for * fluid and not the other one. I have run homogeneous model, i wanted to compare the results with inhomogeneous model. Thanks, Ashish
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Inaccurate velocity vectors Arun Prasad FLUENT 4 August 2, 2012 00:43
how to display a clear vectors of velocity clauss FLUENT 1 October 24, 2006 07:30
Velocity vectors clipping Vidya FLUENT 0 July 31, 2006 21:53
velocity at porous region CHUBBY FLUENT 3 May 15, 2001 23:37
