dynamic material properties
Hi everybody,
Is it possible to set material properties in CFX-Pre which are dependent from the current region/subdomain? I have following case: Air flows through a domain and in this domain is also a porous subdomain. I like to have a different orthotropic thermal conductivity for the air in the porous subdomain as in the rest of the domain. How can I implement it in CFX? Thanks a lot, Greg |
Re: dynamic material properties
Hi Greg!
You can define your thermal conductivity using a CEL-variable. This can again depend on the subdomain via the CEL-Function inside. inside()@Subdomain_Name takes the value 1 in the subdomain Subdomain_Name and zero otherwise. Hope this helps. - Terje |
Hi Terje!
Thanks a lot for your help, this CEL-Function is very helpful for my purposes. Greg |
