Home > Forums > CFX
Mass Flow rate
Old   July 2, 2007, 01:34
Default Mass Flow rate
Wespl
Dear All, Can you please tell me how to visualize the mass flow rate from CFX post if i am using the variable mass flow given in CFX it is giving me some negative values. Looking forward your valuable reply.
Thanks and Regards Wespl.
Old   July 2, 2007, 18:30
Default Re: Mass Flow rate
Negative mass flow means the net flow is in the reverse direction. Isn't that pretty obvious?
Old   July 3, 2007, 05:18
Wespl
Thanks Horrocks, Can you please tell me how to get the mass flow rate from CFX. i thing what i am doing is not a correct method to capture the mass flow rate.
Thanks and Regards
Old   July 3, 2007, 18:27
You can get mass flow rates as the simulation progresses using a monitor point, and you can also get it from a finished run in CFX-Post using the tools/function calculator.
Both of these methods are discussed in the documentation.
Old   July 6, 2007, 23:52
Wespl
Dear Horrocks, Thanks for your reply, and it is useful for me to take out the results and i would like to know if my boundary condns are Total pr at the inlet and Static pr at the outlet. what can be my soln i took the velocity and it seems to be correct but not the pressure so if i need pr soln what shud be my boundary condn.
Thanks and regards Siva.K
Thread Tools
Trackbacks are On
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 20:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
Particle Injection Mass Flow Rate and Position leonozx FLUENT 2 April 29, 2011 09:19
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
