Solver Error
Hi,I'm using CFX 11.0 with a 64 bit. My calculation concerns a rotating mesh deformation. When I start the solver it give me this error:
ERROR #001100279 has occurred in subroutine ErrAction. Message: REDHDR: locating dataset failed: what=G/NFC where=ZN1 Solver give me this error just read the model and before to start solution. Do you have some idea? Thank you! |
Re: Solver Error
This looks like a similar bug related to the patch-independent mesher - did you use to create your cmdb file in the Meshing Application? If so, you can do one of two things: 1. Use CFX-Mesh, or, 2. Talk to your support office, who should be able to make a fixed library available to you. Regards, Johnson |
amjidkhan
Hello everyone!
I am getting this error and don't know what exactly the problem is? please guide me regarding this problem, will be very thankful ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | REDHDR: locating dataset failed: what=G/NVXZIF where=ZIF1 | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine REDHDR |
