Solver Error
Old   July 4, 2007, 06:20
Default Solver Error
eros
Hi,I'm using CFX 11.0 with a 64 bit. My calculation concerns a rotating mesh deformation. When I start the solver it give me this error:
ERROR #001100279 has occurred in subroutine ErrAction. Message: REDHDR: locating dataset failed: what=G/NFC where=ZN1
Solver give me this error just read the model and before to start solution. Do you have some idea?
Thank you!
Old   July 4, 2007, 08:03
Default Re: Solver Error
Johnson
This looks like a similar bug related to the patch-independent mesher - did you use to create your cmdb file in the Meshing Application?
If so, you can do one of two things:
1. Use CFX-Mesh, or,
2. Talk to your support office, who should be able to make a fixed library available to you.
Regards,
Johnson
Old   September 30, 2019, 01:47
Thumbs up amjidkhan
Amjid Khan
amjidkhan is on a distinguished road
Hello everyone!
I am getting this error and don't know what exactly the problem is?
please guide me regarding this problem, will be very thankful
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | REDHDR: locating dataset failed: what=G/NVXZIF where=ZIF1
| ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine REDHDR
amjidkhan is offline   Reply With Quote
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
