Home > Forums > CFX
Moving Mesh
Old   July 16, 2007, 00:25
Default Moving Mesh
Wespl
Hi All, I would like to generate a moving mesh and my problem is of turbine rotation and i know the velocity and i want to know the rpm for the corresponding velocity. and i culdnt find the mesh deformation option in my CFX10 so can you please tell how shud i apply the mesh deformation.
Thanks in advance
Old   July 16, 2007, 12:27
Default Re: Moving Mesh
Gert-Jan
What do you want to deform? I hope you do not want to use deformation to let your turbine rotate?
If you want to rotate your turbine, you have to create two domains with a rotating mesh and a stationary mesh. Put the rotating parts in the rotating mesh and the rest in the stationary part. Then let the rotating part rotate with the known velocity and find out what the fluid does.......
Good luck, Gert-Jan
Old   July 16, 2007, 15:20
hayate
hello
can i ask something?????
if we already know the velocity of the air... and we would like to know the rotational velocity of the turbine??? how can we set this up??? i mean the opposite that gert says..
thanks a lot
hayate
Old   July 16, 2007, 16:24
Amir Jourak
hi,
I'm doing the same simulation for rotor. Gert my problem is the solution converge really good and fast for the steady state solution but for transient solution it does not converge at all, when i change the time step and trying to keep the coarent number around 1 for water as a lubricant the solver keep fluctuating and i will not have any result at all. Do you know any solution or trick.?! i don't know how i should find an answer for transient simulation.
Old   July 17, 2007, 00:45
Wespl
Thanks Mr.Gert, i did a problem for my micro air vehicle with flapping wings in that we used only mesh deformation option to flap the wings. so i am not much aware of propeller blades and i dont ve any idea of rotating mesh. is that we ve to apply domain rotation? option in cfx10
Thanks and regards Siva.K
Old   July 17, 2007, 16:16
Gert-Jan
Try a tutorial with rotating domains first. You will find out that two meshes are required, a stationary and rotating domain and that you need sliding interfaces between both domains.
Gert-Jan
Old   July 17, 2007, 17:36
Gert-Jan
You want to set the velocity and find out how fast your turbine will rotate. Not sure how you can do that using CFD. Out of the blue..............
First you have to know how much force on the shaft is required to let your turbine rotate. If you know that, I think you should do:
- perform a simulation with your velocity on the inlet and let the turbine rotate with a well-guessed omega;
- describe a relation omega = omega(Force), based on your dynamo data.
- Set the rotational velocity omega on your tubine while Force is the force the fluid act on the turbine. This can be calculated using areaAve(Force)@turbine.
This way, I guess that the final rotational velocity and the acting force will give an equilibrium with the force of your dynamo.
Momentum and force are mixed up a little but this is the way to go, I think.
Good luck, Gert-Jan
www.bunova.nl
Old   July 17, 2007, 17:50
Gert-Jan
Well, what is converged? You need to be sure that within a timestep you obtain convergence. How many coefficient loops do you use in each timestep?
I guess that within a timestep you don't obtain convergence. What can be done?
- reduce time step?
- improve the grid on the GGI's?
- are you sure you can obtain convergence? Is the flow around the turbine converged but in other regions not? In other words, where is the solution fluctuating?
- are all BC and interfaces well defined?
Gert-Jan
Old   July 18, 2007, 11:38
eros
I have to simulate a rotating cranckshaft.I tried with rotating mesh but it doesn't work. So I'm trying with two different domain: fluid domain and the crank (defined as a solid domain).My idea is to put crank in a FRF and crank case in a stationary frame of reference, but I encountered some problems:
- How can I define a RFR, when I define a new frame of reference this option isn't activate - For solid domains is not possible to set any frame of reference. - It isn't possible to define a rotating solid domain
Have you some hints?
Thank you very much!
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Waves halted by moving mesh Piotr Czajko Main CFD Forum 1 November 24, 2007 03:00
