July 16, 2007, 23:43 |
polynomial curve in CFD workbench
can we make polynomial curve and then extrude it in the ANSYS Workbench??let say i want to make 5th order curve...how can i make it??thanx...
July 19, 2007, 03:06 |
Re: polynomial curve in CFD workbench
My best guess would be to put the equation in excel and generate a couple points. Then you can use the create points utility to read a *.txt file to read them. Make a polyline of the points adn then extrude it. Hope it helps
Prachi |
July 19, 2007, 05:36 |
thanx...exactly i want to make a axismmetric contraction shape using polynomial equation.what do you mean by generate a couple points??I've made an equation in Excel..how can i put all the points in the design modeler??
July 19, 2007, 06:13 |
Fadly,
If you ahve the explicit co-ordinates. here is how you can generate them in workbench Coordinates File This option allows you to specify a text file from which to read coordinates. These coordinates are used exactly as specified and are not projected onto any face or edge. The file itself must be a simple text file formatted according to the following rules: After a pound sign '#,' everything else on that line is considered a comment and is ignored. Empty lines are ignored. Data consists of 5 fields, all on one line, separated by spaces and/or tabs: Group number (integer): must be >0 Id number (integer): must be >0 X coordinate Y coordinate Z coordinate A data line with the same Group and Id numbers as a previous data line is an error. Number of points is limited to the value set in the Options dialog box (see the Point Feature Limit setting under the DesignModeler Miscellaneous settings in the Options dialog box). The Refresh property for this option allows you to update your text file and have the system read it again. Since the Group number and Id number fields uniquely identify each point generated for this Point feature, this allows you to modify coordinates, or delete or add points. A sample coordinates file is shown below. # List of Point Coordinates # Format is integer Group, integer ID, then X Y Z all # delimited by spaces, with nothing after the Z value. # Group 1 1 1 20.1234 25.4321 30.5678 1 2 25.2468 30.1357 35.1928 1 3 15.5555 16.6666 17.7777 #Group 2 2 1 50.0101 100.2021 7.1515 2 2 -22.3456 .8765 -.9876 2 3 21.1234 22.4321 23.5678 I hope this helps. Prachi |
July 19, 2007, 23:40 |
I think Prachi is right this is one approach, but i was wondering if there was a way to give the coordinates implictly, means that give the value of x and y will be calculated from the expression ie x=Ay**5+By**4+c and A,B,C can be used as parameters for optiisation,so that i can optmise the curve of converging area of nozzle. Talha |
August 2, 2007, 05:07 |
I am not aware how one could do it in the way Talha suggested. It would be awesome for optimisation studiesif it can be done. |
How to integrate ICEM CFD with Ansys Workbench ? | radompon | CFX | 9 | July 1, 2009 16:12 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | September 13, 2000 04:48 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
