-   -   How to read a file with inlet velocity data? (http://www.cfd-online.com/Forums/cfx/24275-how-read-file-inlet-velocity-data.html)
dorin July 17, 2007 06:49
Hi!
I simulated two-way fluid structure interaction running an ANSYS Multi-field (MFX) simulation with constant inlet velocity, now I try to set a inlet velocity which is variable with time step. I want to read a file which have the inlet velocity data variable with time step. How can I do this?
Thanks!
opaque July 17, 2007 09:37
Re: How to read a file with inlet velocity data?
Dear Dorin,
Is it a function of time only, or a function of space as well? For the former, just type in a 1d CEL interpolation function..
For the latter, there are ways of achieving this but I advice you to contact the CFX help desk.
Opaque
dorin July 17, 2007 14:46
Dear opaque,
Thanks for your help. It is a function of time only. I try to simulate a transient two-way fluid structure interaction running an ANSYS Multi-field simulation with inlet velocity have a different value for each timesteps , the timesteps is the same timesteps which I enter in Simulation Type tab. I have a file with two column, first column have timesteps value and the second has velocity value, I try to introduce this file as a inlet velocity. How can I do this?
Thanks!
Dorin
opaque July 17, 2007 15:27
Dear Dorin,
Please search the documentation for "one dimensional interpolation" and it explain to you how it works.
At the end of that document, there is the explanation of "importing data from file"
Opaque
dorin July 18, 2007 07:35
Dear Opaque,
Thanks for your help. I search in the documentation and I understood that Coordinate column accept coordinate axis dimensions (e.g., [m], [cm], etc.) and in the Value column I understood that I can put velocity value. This mean that the velocity is variable with coordinate. What I want is to set velocity variable with timesteps, in Coordinate column I want to have timesteps, for example I have a total time of the simulation 0.7 s and the timesteps 0.007 s and I want that inlet velocity(U) to have a value of 0.1 m/s at timestep 0.007, a value of 0.2 m/s at timestep 0.014, a value of 0.3 m/s at timestep 0.021, ..., a value of 10 m/s at timestep 0.7. I have this values in a file, when I Right-click in the window to import data from a file the value of timesteps are written in Coordinate column and the value of velocity are written in Value column. Please tell me if it is O.K, because I understood that in Coordinate column I can put only the coordinate axis dimensions (x, y, z).
Thanks!
Dorin
opaque July 18, 2007 08:02
Dear Dorin,
It should be OK (at least for 1D interpolation)..
Unless your file is really large, I would input the data directly into the GUI..
Opaque.
dorin July 18, 2007 09:17
Dear Opaque,
Thanks! In this case it is O.K to put in Argument units [s] and in Results units [m s^-1]? Please tell me how I set the velocity in inlet boundary?
Thanks!
Dorin
opaque July 18, 2007 09:41
Dear Dorin,
Here is an example,
FUNCTION : MyVelFunc
Option = Interpolation
Result Units = [m s^-1]
Argument List = [s]
INTERPOLATION DATA :
Data Pairs = 0.00, 1.0, \
0.01, 1.0, \
Extend Min = True
Extend Max = True
END
END
Then, in you inlet you will type something like
MASS AND MOMENTUM:
Option = Normal Speed
Normal Speed = MyVelFunc(t)
END
Hope this helps,
Opaque
dorin July 18, 2007 11:31
Dear Opaque,
Thanks a lot, that was really helpful!
Dorin
Dr. Flow Squad July 19, 2007 02:38
If your velocity profile is that simple, why don't you use an expression for the velocity? U = U0 * t/1[s] ? - Dr. Flow Squad
dorin July 19, 2007 06:23
Hi Dr. Flow Squad!
Thanks! The velocity profile which I written in the message is a simple example and it is a good idea to use an expression, but I want to know, in case that the velocity profile is not that simple and it is hard to put in a expression, how to read a file with velocity data.
I search in archives and I found this address http://tinyurl.com/2gkjh8 and I see that you simulated cylinder in cross flow, please send me, if it is possible, the command file and the geometry file for this problem, it will be very helpful to me.
Thanks!
Dorin
Dr. Flow Squad July 19, 2007 07:01
It's not the best mesh I've made, but here it is: http://users.cybercity.dk/~ida3068/cfd/2dcylinder.zip - Dr F.S.
dorin July 19, 2007 12:37
Hi Dr. Flow Squad!
Thanks!
I create a new simulation, I import gtm file after that I import ccl file and I have some errors:
Initial conditions are required for transient simulations (unless you select an Initial Values file from the Solver Manager).
There are 2d regions in boundary 'Domain Interface 1 Side 1' in domain 'Domain 1' that have already been used.
The parameter "Location" in "/FLOW/DOMAIN:Domain 1" holds the following disallowed value: "Assembly 3". (Allowed values are: "Assembly 2, B30, B30 2, Assembly".)
The parameter "Location" in "/FLOW/DOMAIN:Domain 1/BOUNDARY:in" holds the following disallowed value: "in". (Allowed values are: "Assembly 2, Default 2D Region 2, in 2, out 2, ...".)
The parameter "Location" in "/FLOW/DOMAIN:Domain 1/BOUNDARY:symside1" holds the following disallowed value: "Default 2D Region". (Allowed values are: "Assembly 2, Default 2D Region 2, in 2, out 2, ...".)
Please tell me what happened, I did something wrong?
Thanks!
Dorin
Dr. Flow Squad July 20, 2007 02:16
Within pre I reflected the geometry (w. copy) to get the full domain. Maybe it has to do with that, I don't recall. Change the settings to stationary to get a start value that the transient simulation can start from. Good luck. otherwise contact me directly through email. this is not forum related any more.
