[Sponsors] | |||||
I want to vary the pressure from 0-5 bar at the inlet by the time interval of 0-5 sec. How this can be possible ? |
Yes it is possible. If you have a function with respect to time, you can use the Expressions tab for this purpose.
Can u pls tell me the expression.I badly in need of it.
Create a 1D function in Pre, say you call it myPressure. Enter coordinate units of [s] ) and result units of [Pa]. Enter coordinates and results for 0 [s], 0 [Pa] and 5 [s], 5 [Pa]. Turn on extend min and extend max. To use the function, enter the following expression in your boundary condition for pressure:
myPressure(t) That's it. Regards, Robin |
Hi Robin,
Thanks a lot,I am not able to understand clearly Can u pls give it in expression format. That would be helpful to do my project successfully I want to vary the pressure from 0-5 bar during the time intervel of 0-10 sec at inlet. For every 2s the pressure should be varied. Can u give it in expression format pls. |
Read the doc on 1D profiles. It should be fairly obvious how to do this.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
| Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
| Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
| Operating condition in Fluent | MASOUD | FLUENT | 3 | September 16, 2010 17:50 |
| Calculation of the Governing Equations | Mihail | CFX | 5 | July 25, 2008 17:29 |
