calc in table viewer
Old   July 25, 2007, 16:48
Default Re: calc in table viewer
  #21
Robin
Post your exact expression here, along with all the expressions it depends on.
Old   July 25, 2007, 19:01
  #22
jan
=areaAve(0.5*Density *(u^2+v^2+w^2))@Default Domain Default
strange thing is that i have a speed of 15 m/s so u^2 should be 225
but i get 266.956 in joule kg^1
so am i not getting things?
Old   July 26, 2007, 09:09
  #23
Robin
Hi Jan,
The expression looks fine, except as I mentioned earlier in this thread, you should not be calculating the dynamic pressure at a wall; it should be taken at your inlet.
As for the return value of (u^2+v^2+w^2), the units are correct, 1 [Joule/kg] = 1 [m^2/s^2]. If you look at v and w in the same region you'll find that they have a small value on the order of 6 m/s.
The expression is fine as is and works for me here. I suggest you contact customer support if you are still having issues.
Regards, Robin
Old   July 26, 2007, 12:37
  #24
jan
hi robin
thanks for the answer but i am still puzzeled for the speed since its totaly off
so where sould i take the speed wich i am starting with that is 15 m/s normaly you would say velocity u but it give me more then 16 m/s
every where i try to get the good speed wich is as i said 15 m/s i get more the 16m/s on wall or outlet or inlet keep geeting the wrong speed
i double checked i start with 15 m/s so.....................
Old   July 26, 2007, 12:55
  #25
Robin
If you have a constant velocity of 15 m/s at the inlet the development of boundary layers will force the flow to accelerate away from the wall, hence the higher velocity. If you want to use 15 m/s to calculate the dynamic pressure, just enter it explicitly.
-Robin
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 13:42
Refering to cells in table viewer Daniel CFX 1 May 11, 2006 12:19
Table Manipulation furkan Siemens 0 April 4, 2006 10:23
transient results in table viewer Andrew Fine CFX 2 December 15, 2005 23:39
Rotation flow calc. II. Andy Christian Main CFD Forum 2 April 10, 2003 04:06
