Radiation Model
I'm modelling a room which is cooled by chilled beams. I'm looking at worst case summer. I don't have a Monte Carlo radiation licence, but am thinking about using the discrete transfer model, surface to surface transfer mode, with a gray spectral model. At the window boundary conditions, the boundary is modelled as an opaque wall, with emissivity 1 and diffuse fraction of 1 (in the absence of any better value). Does anyone have any views on the assumptions I've used? Any advice would be greatly appreciated :) Thanks in advance, Nicki |
Re: Radiation Model
Hi Nicki,
When I did some similar work I found the discrete transfer model the best to use. Do a quick validation case of one plate heating up another plate with an analytical answer to check everything is working before proceeding. Glenn Horrocks |
Re: Radiation Model
Dear Nicki,
I would agree with Glenn's advice; however, be careful with a geometry with large aspect ratio. The quality of the DTM solution decreases as aspect ration increases with a fixed number of rays. That is, you ray count must go up as the aspect ratio increases. Ask your help representative for the radiation report showing this behavior for DTM/MC.. Hope this helps, Opaque |
