Forces in Transverse direction
Old   August 6, 2007, 12:46
Default Forces in Transverse direction
Virag Mishra
Hi My problem involves unidirectional flow along the X axis its an external flow problem with body over which the fluid is flowing being symmetrical about the X axis. To my surprise when i'm constructing a structured mesh i'm not getting any force in Y and Z direction, but a non zero force value when i'm using tetrahedral cells.
Old   August 6, 2007, 18:25
Default Re: Forces in Transverse direction
Is it a significant force? You will not get exactly zero force, but if the flow is truly symmetrical it should be an insignificant force.
Alternatively if the flow is non-symmetric then you could be seeing a non-symmetric wake. Then there will be a significant cross force.
Old   August 6, 2007, 23:07
Virag Mishra
Ya, as i said the force is significant if i'm using unstructured mesh; but not in a hexahydral mesh case.
Old   August 7, 2007, 08:54
brunoc
Have you done a mesh refinement study?
Old   August 7, 2007, 10:32
Virag Mishra
ya quality is fine. and mesh is getting exported.
Old   August 7, 2007, 18:18
Brunoc was asking about a mesh refinement study. This checks whether the mesh size you are currently using is adequate to resovle the important features of the flow. This is a different thing to mesh quality.
Regards, Glenn Horrocks
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 03:28
FORCES don't run! C12Carbon OpenFOAM 0 September 10, 2011 07:34
Forces calulated through pressure LVDH OpenFOAM Post-Processing 2 February 26, 2010 03:15
Forces in Symmetry Matt CFX 2 February 25, 2009 05:41
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 14:09
