Batch file on Windows XP
Old   August 13, 2007, 08:20
Default Batch file on Windows XP
Hervé
I am normally running ANSYS on LINUX but I have to work for a while on WINDOWS XP
How does a batch file look like on WINDOWS XP and how do I run it ? I have looked - a bit - at the tutorials but it hasn't helped me that much.
Do you have any example I can use ?
I want to solve several .def files in a row.
Regards,
Hervé
Old   August 13, 2007, 16:19
Default Re: Batch file on Windows XP
Joey2007
One possibility may be to use perl. It is installed with CFX installation and may be similar to things you are using under linux.
Old   August 13, 2007, 18:19
It is all described in the documentation. Have a look in the Solver Manager doco, under "Starting CFX from the command line".
You will find a windows batch file is pretty much the same as a Linux/Unix script.
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
