merging edges in ICEM
hi
i have a structured meshing, the problem is that i need to specify equal node distances on my geometry and the edges are splited by various vertices, is there any option to merge the edges about a vertex. |
Re: merging edges in ICEM
you can manually merge the blocks. that way you will be able to merge the two faces (which describe the blocks), and thus able to remove the vertex
Thanks, The problem actually is that I have deleted the blocks, and this edges belont to the outer end of the blocks is it possible now?
You can copy the edge distributions from one edge to another - use 'Absolute'. As long as the edges are the same length - the distributions will be the same.
Hey Virag. You may try this. You can transform opposite face of the face you have deleted. This way you will get a complete block.
