cfx-error
Old   August 21, 2007, 15:35
Default cfx-error
Hamidur Rahman
Hello, I am working on CFX as a beginner. My case is simillar to the Tutorial file 12. I used same boundary condition but with dfferent mesh. When I run the case after 7 iteration the following error messege observed. Is there any one help me out of this problem? Thanks
****** Notice ****** | | A wall has been placed at portion(s) of an INLET | | boundary condition (at 0.1% of the faces, 0.2% of the area) | | to prevent fluid from flowing out of the domain. | | The boundary condition name is: S1 Inlet. | | The fluid name is: Air Ideal Gas. | | If this situation persists, consider switching | | to an Opening type boundary condition instead.
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow
Details of error:- ---------------- Error detected by routine POPDIR CRESLT = ILEG
Current Directory : /FLOW/NAMEMAP
Old   August 21, 2007, 15:36
Default Re: cfx-error *NM*
Hamidur Rahman
Old   August 22, 2007, 07:14
Pankaj
This overflow error is due to some basic physics description errors i.e. solver is diverging. Go through manual for obtaining convergence.
Also extend your outlet to remove recirculation.
Regards, Pankaj.
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
