August 25, 2007, 08:53 |
pollutant dispersion
hi
i'm simulating a dispersion of pollutants on atmosphere. the pollutants are emited from a source as an additional variabele, which are different from the air. But in the CFX-pre, there is no any option for setting the characteristic of the addition variable(pollutants). i wonder how to set the characteristic of the additon variable like the density,buoyancy etl. Thank you very much! by the way ,i want to make friend who are also interested in this field. |
August 26, 2007, 18:41 |
Re: pollutant dispersion
The additional variable approach does not use density, buoyancy etc. The only parameter is dissipation. If you want to include density and buoyancy effects you will need to use a multicomponent multiphase model, or some other multiphase model. Glenn Horrocks |
Pollutant dispersion in the environment | alberto | OpenFOAM Running, Solving & CFD | 24 | November 29, 2014 13:31 |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
Turbulent Dispersion for Coal Combustion | gravis | CFX | 2 | March 23, 2010 23:56 |
Simulation of pollutant dispersion in a city | George | Siemens | 1 | June 27, 2007 04:26 |
Question on Dispersion | Mike Marcu | FLUENT | 2 | September 14, 2005 19:53 |
