One to one connection for periodic faces
Old   August 29, 2007, 02:34
Default One to one connection for periodic faces
Al
i'm trying to set a 1:1 connection on periodic faces, but when i write the .def file, CFX change the connection on periodicity to GGI. I have just augmented the Mesh Match Tolerance parameter to 0.1 (10%) with no results.
The mesh is generated with Centaur and is in CGNS format. I have just verified in Centaur that no periodic problems are present and it seems to be a one to one connection (the max error is equal to 1e-12 for corresponding nodes).
Moreover, CFX takes several hours to import a mesh (in CGNS format) of 1.300.000 elements.
I am not sure that CGNS file contains any informations about corresponding nodes on periodicity, therefore i am not sure that is possible to set one to one connection for mesh imported in CGNS format.
Can anyone help me???
Thanks
Al
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
